Upgrading to Pro
Mason
I have moved the key to the folder containing the Hwinfo shortcut and restarted the program but it seems its still not registering the upgrade.
Have you moved it into the right folder where the executable is located?
You can also try the latest Beta version 7.47 which has a new License Management tab in main settings that allows you to import the license file.
It was the wrong folder, finding the exe and using that folder worked. Thanks!
