Vega 64 Temperatures Stopped Working
the_gas
Several of my Vega 64 temperature sensors have stopped working, do you know why?
I have tried:
A different vega gpu
a different version of hwinfo64
a clean driver install
deleting my hwinfo config file
enabling amd adl
Everything worked last night afaik.
https://imgur.com/Knu5BTO
Which Vega64 model is that, the Liquid Cooled one ?
Have you perhaps changed the graphics drivers when this happened ?
A HWiNFO Debug File with sensor data would be helpful to check this in detail.
the_gas
I did change drivers yesterday, but it was working okay after changing. It was only this morning that it vanished and then i tried a clean DDU install.
Sorry, but the attached DBG file seems to be broken (truncated). Can you please try again?
Also, is GPU-Z reporting those temperatures ?
the_gas
HWINFO was not appearing in my task bar and i noticed that my GPU kept crashing and locking up the whole system after starting HWINFO. Not sure what happened, but i just decided to clean install Windows and start a fresh.
