G GeneGene Member May 8, 2024 #1 Fresh Win11 install. No vm's of any kind are running. No WSL. The warning still appears. "Microsoft Hyper-V is active. Some results may not reflect real hardware !" What are you checking for that might trigger that warning? Thanks
Martin HWiNFO Author Staff member May 8, 2024 #2 Later Windows versions by default (and during fresh install) enable HVCI (Core isolation) that relies of virtualization.
G GeneGene Member May 8, 2024 #3 Martin said: Later Windows versions by default (and during fresh install) enable HVCI (Core isolation) that relies of virtualization. Click to expand... That generic warning undermines the results of a HWiNFO scan. Can HVCI be turned off in Windows? If not, can you identify exactly which 'results may not reflect real hardware' are impacted? Thanks!
Martin HWiNFO Author Staff member May 8, 2024 #4 All this has been discussed several times on this forum.
G GeneGene Member May 8, 2024 #5 If it was all discussed, I assume you decided to leave in place the near-meaningless 'some results may not reflect real hardware' notification? Any reason you don't specify which results might be bogus? Thanks for the great app, though!
M mnemonic Active Member May 8, 2024 #6 Mainly measured Frequencies were/are affected because of virtualization. No big deal anyway.
Martin HWiNFO Author Staff member May 8, 2024 #7 One example here (pinned thread): IMPORTANT - Core frequency reading in Windows 11 I'm getting some odd looking core frequency readings with the current HWiNFO in Win 11. Is Win 11 supported yet? Screenshot attached. www.hwinfo.com Exact details depend on system and OS version/settings.
