VR VOUT sensor shows 2,75 V under load while stresstesting.
uzzy
Hello, everyone!
Just a couple of weeks ago updated to HWinfo v.8.12. Then, testing my PC using LinX, I have by mere chance spotted abnormal, imo, VR Vout (Vcore) min. 0,445v (idle) up to max. 2,75V @ 183W load / 4600Mhz / VIDs 1,24v / Vcore1,208v. Vcore set manually 1,3v in BIOS. Temps OK. Never before I checked this item and don't know if it is a problem.
MB: Asus tuf gaming b560-plus wifi, CPU: i5-11600kf stock, unlocked PL1/PL2.
Update: OCCT shows VR Vout as 2.055v @ 133W load (test CPU).
** Updating to v.8.14 changed nothing.
That might be a faulty readout from sensor. I'd need to see the HWiNFO Debug File capturing this.
Looks like this value (under OnSemi NCP81229) is not reliable, I'd recommend to ignore it.
