Are you using the HWiNFO plugin in MSI AB to pull data from HWiNFO or did you configure HWiNFO to show data in RTSS?
You might try to change in Regional settings the following setting if that will help:
You might try to change in Regional settings the following setting if that will help: View attachment 7027
