VRM Temperature on Asus H110S1
yurius
Good day. With new version of hwinfo vanished VR VCC Temperature (SVID). It was not very stable and one of two or three runs this tempreture didn't show up even on 6.24. But with version 6.26 it totally dissappeared, tried 10-15 runs and no luck
  • HWiNFO64-6.24.4120.0.DBG
  • HWiNFO64-6.26.4160.DBG
yurius
With this build works fine, thnx! Will this fix available in next stable versions of hwinfo?
Yes, of course it will be available in all new builds. I'm even considering an interim release because of this bug in v6.26.
Can you check whether it works now more stable than before?
yurius
Have interesting results (as for me)
10/10 success 6.24-4120 with debug mode ON
8/10 success 6.24-4120 with debug mode OFF
0/20 success 6.26-4160 without no dependency to debug mode
6.27-4161 equal results with 6.24-4120 - 10/10 with debug and 8/10 without.
yurius
Ok, I have email notifications to this thread, so if there is any need of info or tests from me - i can do this.
Would be interesting if you could catch in Debug Mode a situation when the sensor fails to show up.
yurius
find one
Thanks. Seems the VR is sometimes not reliable and doesn't respond. Will try to improve this even more in the next build.
yurius
I can see this behaviour in gui sometimes, VRM temp string changing colour, see screenshot
A grey value means HWiNFO is not able to read a valid value from the sensor, so that's still the same issue.
