vrm temps
graph
hi guys,
i'm not sure with which version of hwinfo64 the vrm temp for my asus gtx 670 did show, once or maybe twice just after a fresh os install, but now it will not be displayed in any version it seems.
cheers
On some nVidia GPUs it seems only the driver installing process enables the GPU VRM sensors, so if you install a new driver, you might see them in HWiNFO.
Unfortunately there's no solution how to make them visible always, since nVidia won't tell how to enable them, nor doesn't leave them visible all the time.
