What will hwinfo monitor when the layout minimized with two system tray sensors?
sgon00
Hi, I am new to hwinfo. I have added two sensors to system tray icons, `Total CPU Usage` and `CPU Core temperature`. I only need the two monitoring in the taskbar/system-tray. To reduce system resources overhead, I am wondering what hwinfo will do in the background. I figured out I had to minimize the layout instead of closing it. The layout shows it monitors all sensors. Will hwinfo monitor all sensors in the background? Should I turn off all other monitoring sensors in layout settings to reduce resources overhead? Should I care? Thank you very much for your help.
HWiNFO will still monitor all sensors, you'll need to explicitly disable those you don't need by pressing the Del key over them. Best is to disable entire sensor (so Del over the sensor heading) you don't need.
