Thanks, it great to hear that it works correctly on Windows 8 pre-release too!
The reporting of Windows version string will be fixed in the next build.
For me it's no problem, but some of those internal builds may contain experimental stuff that might not work properly on some platforms (I usually send them to single users for testing).
I usually pull such builds quite fast. Anyway, most of them are improvements..
