Wrong battery percentage in tray
Lxx
I noticed that when battery have 79% icon in tray shows 78.
Is this just a temporary issue, so that the value in tray will jump to 79% after a short while (1-2 update cycles), or does it stay at 78% for longer ?
Have you observed such discrepancy at other levels as well ?
Lxx
It never shows 79%.
No, because I didn't even charge/discharge battery since I activated this tray icon (I have charge level limit set to 80% so it is frequently occurring value).
Lxx
I tried beta - it was working OK, then I started build 2350 - it also working OK... So I'll trust you and assume it's fixed. ;)
