thats why i need to know the vrm temp haha but then my gpu does not support that. because right now, the temp when stress test is 68C for global and memory temp, 70 for junction temp. to me all is good but im worried about the contact of the thermal pad to the vrm haha. and i also hope not to change the thickness of the vrm thermal pad because it may cause higher temp for the other causes by the less contact for the memory and gpu die due to a bit thicker vrm padbe careful though, thicker pads may cause bad contact between the cooler and the GPU die![]()
