Z490 Dark Kingpin Die Sense voltage readings
seranidy
Hi, I was wondering if it would be possible to add Die Sense readings to the next revision of hwinfo for the z490 dark kingpin? The board uses the intersil ISL99227 Smart Power Stages, and I am 50% sure they use the same controller as the z490 ftw which is the Intersil ISL69138 Thank you
I'm not sure if the PWM is accessible there. Please attach the HWiNFO Debug File with sensor data for analysis.
