Hello!
I noticed that POUT and IOUT are much lower than they should be in 7.00, 7.02, and now 7.04 beta hwinfo64 releases. In the imgur album below(3 pictures), it can be seen that there is a 100w+ difference software readings and a Kill-A-Watt power meter that the computer is plugged into. This also happens in both BIOS versions available as well as if the BIOS is fully at default settings. The test ran to compare power and current usages was Cinebench R23.
Specs: Z590 Elite @ BIOS version F1 and F2
10900kf @ Stock & Overclocked to 5.4ghz/Override/1.4v/Hyperthreading off
2x8gb Gskill 3600 cl15-15-15 1.35v @ 4500mhz cl16-17-17 1.58v
GTX 660 OEM
Corsair 750w RMX
Here is someone else I know with a Z590 Elite and 10600k seeing the same incorrect behavior.
Here is someone I know with a Z590 Ultra seeing correct behavior. I had them run similar(ended up being lower) voltage and clockspeed with hyperthreading disabled(10900k/f).
I could not find an option to create a debug file under options, if someone could let me know how that would also be fantastic!
GTX 660 OEM
Corsair 750w RMX
