It seems like there are some issues with monitoring of the 4090.
Whenever I monitor it (Hwinfo, or other suites) there are sometimes long delays between frames.
Looking at HWINFO - it seems that the latency to retun readings from the 4090 go into the thousands of ms - see attached (latency reading of 1616).
This is whilst playing a game - Hitman (alt-tabbed out to grab the screenshot).
I have had this issue from FanControl as well - using the built in sensor readings.
Any ideas on how to fix this??? Or do I just not monitor the card.
I have seen suggestions that this could be down to Nvidias NVML API not being updated / monitoring suites using older non-supported APIs.
