Hey guys, i just built my new pc and im witnessing something in hwinfo64 thats a bit weird to me even tho i dont know if its an issue or not,
on my 13900kf thats used on a gigagyte z790 aorus elite ax ddr5 rev 1.2, Core 0 is the only core thats currently going to random idle at 800mhz while all the other cores boost to max, visible in the following screenshot
my full specs are:
MB: Gigabyte z790 aorus elite ax ddr5
CPU: intel 13900kf
GPU: gigabyte rtx 4080 gaming oc
RAM: 32 gb Corsair vengeance rgb 7200 mhz cl 34
AIO: Lian li trinity 2 galahad performance 360
Power Supply: Be Quiet Straight Power 12 1000watt platin
Windows 10 pro
would be awesome if anyone could help me with this cause im not quite sure if my system is running the way it should, im not manually overclocking anything, i didnt change my bios besides the preset of optimization which should boost the cores to max.
any help much appreciated let me know if u need any further info
my full specs are:
CPU: intel 13900kf
Windows 10 pro
