P peterdk New Member Sep 8, 2024 #1 I run my Windows 11 on 200% scaling on a 4k monitor. Somehow HWInfo64 cuts a bit off the bottom of the window. It looks weird. I am not sure if there is actual information lost or that just the padding is wrong. Last edited: Sep 8, 2024
Martin HWiNFO Author Staff member Sep 8, 2024 #2 Does it appear the same if you do a Reset Preferences in HWiNFO?
P peterdk New Member Sep 8, 2024 #3 It's the same. I did a reset of prefs, restarted the app, no change.
Martin HWiNFO Author Staff member Sep 8, 2024 #4 I see.. Will try to fix this in the next (Beta) build.
Martin HWiNFO Author Staff member Sep 11, 2024 #6 This should be fixed in new Beta build: https://www.hwinfo.com/forum/threads/hwinfo®-v8-11-5540-beta-released.10025/
