Any way to keep related Sensor Tray Icons together?
musterfox
Hi
Just downloaded and installed the latest version.
The Sensor icons I have selected (CPU Core Temps and SSD Drive Temps) show up in my tray as follows -
Core 0, Core 1, Core 2, Drive 1 Temp, Drive 2 Temp, Drive 3 Temp and lastly Core 4 (see attached image)
Is there some way to keep related tray sensor icons together as one group ie - all the Core temps together and all the Drive Temps thereafter rather than having them split up this way?
Any advice appreciated.
Cheers
Dalai
Move them into position the way you want them, then exit HWiNFO at least once. Windows should take care of the rest since it saves the position of tray icons.
Regards
Dalai
