Asus CH6 no info
ironcobra
Im not getting any information from my asus ch6 or corsair h115i. Where do i begin to troubleshoot, all other sensors are working. Thanks
What information are you missing, can you attach a screenshot?
Also attaching the HWiNFO Debug File from your system would be helpful to diagnose the situation.
ironcobra
Here you go, thanks.
Monitoring of those sensors is disabled (by user). Just hit the Ins key over the sensor heading and all should appear ;)
ironcobra
Thanks for the fix, glad it was very easy :D
