Automatically deny Embedded Controller Sensor and continue
lumpy2000
Is there a way to tell HWiNFO not to use Embedded Controller Sensor by default using some switch when running hwinfo or setting in the ini file?
Generally speaking, I do not want this warning message to stop the HWiNFO process and prevent from data reading over network.
There are a few choices:
1. You can either dismiss the message and prevent it from being displayed again but ticking the "Don't show this warning again" box.
2. This warning can be completely disabled in registry by setting the "WarningShow" value to 0 for the respective sensor under: HKEY_CURRENT_USER\SOFTWARE\HWiNFO64\Sensors
3. You can completely disable Embedded Controller (EC) support by disabling the "EC Support" option in general settings of HWiNFO. This equals to the LPC=0 option in the INI file. Note that by disabling this option, you will loose all EC sensor values.
Hi...i am a new user here. Before you start on configuring your sensors, I would strongly recommend you to get SDK samples working on your Embedded system so that you can use the MQTT functionality to talk to AWS IoT.
