Hello Martin und Grüsse aus Deutschland
I have a question that has probably already been asked a mio. times, but i cannot help myself as to ask again, as the search didnt bring me a good answer, i just got the feeling there is no general answer for all systems.
I appriciate the application and have always 7 or 8 values on screen, which i can put on and off with 1 button, pretty handy and useful. Only problem is the core temp. Im experimenting with different fans and speeds and airflow and so on. So it would be good to know the result for sure. There seem to be a few values which are related to the core temp. I would like to know which ist most accurate and it would be perfect if i was able to understand all of them
1. I have an i7 2700k with an Enermax ETS-T40 Cooler and an Asrock Z77 extreme 3 Mainboard.
HWINFO shows me following values/temps
-CPU (#0) Intel Core i7 2700k- shows:
1) The 4 values for the different Cores, which are between 25 and 60 degree celsius and can rise or fall 10 degrees in 1 Second.
2) "CPU Package" Temp
3) "CPU GT Cores" Temp
4) "CPU IA Cores" Temp
-Nuvoton NCT6776F Sensor- shows:
1) "CPU" Temp
2) "CPU (PECI)" Temp
There are a few more values, like auxiliary and systin, which i dont understand, but most most important to me would be to know to understand the CPU Values, which of them is important, "real" ??
Thanks and greetings, mannitu from Hamburg :sleepy:
1) "CPU" Temp
