CPU Fan now dissapeared 4ever
joemumu
One day after doing some major editing of placement of values, I decided it would be a good idea to delete some values and I don't know why. I ended up even deleting CPU Fan from the bottom section of the custom page. Idiot! Well I've been trying everything I could think of to get it back, but no luck. I tried using a copy of GPU Fan and renaming it.  Idiot! That didn't work either. So at the risk of myself looking like an idiot, could someone tell me if there is a way to slide that value in. The only other way I see is to do a clean install. Then I would have to do all that editing again, but I won't mind so much, cause I'm an idiot!
TIA
It's easy to restore those values. Go into sensor settings (the wheel icon at bottom of the sensors window) and in the Layout tab you can reorganize or bring back hidden items.
