I've noticed that if I have CPU-Z running alongside HwInfo, that CPU-Z shows a lot of frequency and Vcore changes that HwInfo isn't picking up, which obviously affects the calculated Average as well as not giving an accurate current picture.
I note that the default Scan Interval in HwInfo is 2000ms so I lowered it to 1000ms, which appears to be a Global setting and not per-sensor or group but that still didn't seem to make much difference.
Do you know what scan interval CPU-Z uses and whether there's any issues with lowering HwInfo's interval to match? HwInfoMonitor also has it's own interval, defaulting to 3ms and would there be any issues with lowering that to match CPU-Z?
On another matter, the "Log all values for Report" setting also appears to be Global (which is a bit confusing as it's grouped with the "Sensor Monitoring enabled" and "Show Reading" settings which are Sensor/Group specific) and I'm wondering how that differs from the Logging Start button on the Sensors window?
