As you can see from the images, the CPU randomly spikes to high voltages. Over 2 v on soc, which I'm assuming is a bug, since the Vcore and core VIDs are in a safe range.
I'm not sure if its meant to be those values or not.
Specs:
CPU: AMD Ryzen 7 7800X3D
Motherboard: ASUS PRIME B650M-A WIFI II
Ram: Kingston FURY Beast White 32GB
PSU: Corsair RM750e 750W Power Supply
Images 2 and 3 are the default bios settings and the first is the expo, and curve optimizer enabled with all core -30. I'm not entirely sure if these voltages are fine or if I should limit them in the bios.
Specs:
