CPU utilisation
The "perf #7/" denominator is not fixed and might be different on each machine or not present at all.
Check in HWiNFO sensors window how the Core 0 Clock is displayed there and match it with the plugin using to read data from HWiNFO (RTSS, etc.).
There weren't any cores that had perf # next to it. I'll check after work again. Is that the only way to to monitor CPU utilisation?
"Core Usage", "Core Utility" - Expand those nodes
Or "Total Core Usage", "Total Core Utility"
So HWiNFO reads and reports those. Issue is in RTSS which pulls them from HWiNFO.
What exactly? That one shows both Usage and Utility.
Ok it seems to be one of the P-cores, because it was renamed I was confused. So which one do I select to match the built CPU clock overlay?
Sorry, I don't understand what the problem is and you don't understand what I'm trying to say.
