Detecting ATA/SCSI Drive Takes a Long Time Analyzing & Loading
Cmp_Cmndo
Indicates "Not Responding".
I suspect it's the large storage drive with many partitions because Disk Management does the same.
New Retail motherboard & storage drive (4 TB).
Primary & boot drive is Samsung 860 EVO - 500GB
It also affects the Windows 10 load time.
Seagate Seatools & Hitachi DFT tests pass.
Debug file attached.
There's nothing suspicious in the attached DBG file. Try to disable the "ATA Statistics Support" option in HWiNFO if that will improve the scan time.
Cmp_Cmndo
Setting Virtual Memory (paging file) to 0MB seems to have fixed it.
It's Windows 10, so could be something else. I think it has COVID-10, i.e. symptoms constantly changing, cause unknown.
Cmp_Cmndo
Installed AMD Radeon R7 350 graphics card.
It is identified as AMD Radeon R9 M375X.
Cmp_Cmndo
It no longer starts up with that card installed or another known good card installed.
It worked yesterday with no other changes since then.
