Non-crap doesn't prompt you to download the latest beta, and then make changes to the layout of the older version of Hwinfo64 that you've safeguarded (by making a copy of the .ini file and renaming it to .ini.copy), changes made to the older version of the program are made in the registry? WTF? To which deleting the newer version and restoring the original .ini doesn't revert?
Non-Crap also doesn't cause your games to drop down to 5 FPS at various random times and the hangs and refuses to quit via killing the process in Task Manger.
Non-Crap allows you to select multiple entries in "layout"by holding down shift and then deselecting "show".
Having to do this one at a time literally took me like an hour the first time, the attached snapshot is only half of the entries as can be discerned by the position of the slider on the side.
What I wanted to do, and to which there are exactly zero prompts or warnings to allow me to do or to warn me that I'm about to lose about an hours work in "layout", was to simply copy the settings in the copy of the .ini found in Hwinfo64's .exe's folder to the new .ini BUT NOOOOOO, the settings are off in the registry or in SysWow or some crap. None of which is intuitive, and none of which can be simply accomplished in 10 minutes.
WE DON'T HAVE AN HOURS TIME FOR THIS DUDE. THAT'S WHY I DIDN'T UPDATE FOR LIKE TWO YEARS. THIS SAME THING HAPPENED THE LAST TIME.
Look, I like Hwinfo64, but all of the above? I'm simply not going to do it again! Thanks for your work so far. Please take the above as constructive criticism, allow us to keep our old layouts, at least by copying over the .ini settings, not some abstract convoluted non-sense into RegEdit or SysWOW64 or whatever.
Not everyone is a "Power User". You want your free-ware to gain notoriety, to become popular and widely used these are pre-requisites. Any program that asks for an hour of my time simply to make a few simple changes to the data presented isn't going to be on my computer. It's as simple as that. Look at the attached snapshot, that's only half of the displayed completely extraneous information that can only be hidden one at a time (with a 3 second delay to top everything off with each and ever entry).
Also, non-crap also doesn't attempt to get you to install browser tool-bars, which has apparently only now been changed (I had to play mr. detective to try to find a version of Hwinfo64 the last time without downloading some tool-bar BS).
So thank-you Unitoyle for Hwinfo64, I've been using it and recommending it for YEARS now, but I'm simply not going to spend any more energy on this as it is unreasonable and ridiculous.
