Extreme Temps Read on Nuvoton NCT6791D
Balestar
Just installed NWiNFO on my new machine as it was recommended to me by a friend, under the sensors tab, however the Nuvoton chipset registers multiple temperatures (labelled helpfully as Temp3 through Temp6) as in excess of 110 degrees C, I believe (and hope) these are erroneous as the CPU/Motherboard temperature from the same chip currently read 24 degrees C and the CPU sensors on the chipset itself read slightly higher at around 30 degrees C
I've attached the debug file and a screenshot, should I be worried about these readings?
--edit--
For some reason I can't get the debug file to attach properly, here's the screenshot anyway: http://imgur.com/NPfXYt8
Those values are certainly erratic, most probably from not connected sensors.
I suggest to ignore them.
NuclearCoffee
--edit--
I have the same problem with that same chip on a ASRock Z97 Mother board. :s Its not your board so don't panic. I've been running this Mother board since the middle of May this year.It's a false reading, I'll let the programmers explain why I just don't remember.
