aline.tech
I've seen this issue posted multiple times, but the threads never get to a real resolution - so I believe it's still an issue.
No other apps are using these hotkeys as far as I'm aware - and at this point I've tried nearly every key on the keyboard.
Could use some assistance - really don't want to have to reset all this. I'm not seeing any type of "export settings" button to make it easy for me to back all this up.
- Attempted to set a Hotkey for "Sensor Logging -> Enable Toggling Hot Key" (ETHK)
- Hit "OK", got an error about failing to register the hot key.
- Unchecked both "Enable Hot Key to Reset Values" (RVHK)
- Restarted software, got error again, and both values were re-checked and both now shared the same hot key (which I had only set to ETHK)
- Rebooted PC - have app set to start with Windows
- Got the error again - app didn't load
- Manually open app - get the error again, both values checked again and with the same hotkey (again, I didn't set this hotkey for both, RVHK seems to be inheriting the key I'm setting for ETHK)
- Checked and unchecked multiple times, tried to set multiple keys for ETHK and nothing works - and no matter what I put in that field, after UNCHECKING RVHK, when I come back RVHK will have checked itself and inherited the same hot key
- The error persists on every load and I can't get it to stop.
- I attempted deleting both registry keys per another thread, didn't help - they just reset themselves when the app loads like it's pulling from a config file somewhere else
