OSD (RTSS) hotkey toggle blocked
k1ck81
For several days, I have a problem with the OSD toggle hotkey. If I assign a key for toggle the osd while gaming, HWinfo64 blocks it and I can´t use it again. If I press the key it doesn´t regist anything.
First, I thought it was caused by another program that uses same key, but I´ve changed it to randoms keys/combinations and the problem persists.
When I close HWinfo64, this key is working again.
Any help? Thanks!
That seems like the key is working but the OSD doesn't show up for some reason. Depends on what OSD you're using and in which mode / game.
