Feature suggestion - Startup delay
Carr
I have just setup HWinfo and RTSS to use the OSD features and am currently have it so I manually start HWinfo each time.
I have a fan control program that has a customizable startup delay built into its setting for "start with windows", is it possible to implement this feature in to HWinfo? It will make it a whole lot easier for those using it for OSD and sure it is useful in other way too.
I will put this feature on the list. Currently you can adjust this startup delay in Windows Task Scheduler by modifying the HWiNFO task (assuming you have enabled Auto Start of HWiNFO).
