do you mean the ASUS EC: ASUS?This could be caused by reading some sensors (like EC) but without knowing more details about the system I cannot provide any other clues.
You can try to disable monitoring of those sensors by hitting the Del key over their heading.
I have turned off the EC, but it hasn't made any difference. Additionally, I noticed that this problem started after I updated my NVIDIA Display card to version 545.84.Yes, for example.
tried, cannot find which one causing it.Then try to disable other sensors like the GPU until you figure out which one is causing it.
maybe cannot, because I need to use this for my Stream Deck monitoringIt's easy to check this assumption by disabling Shared Memory Support in HWiNFO.
Yes, turn off will solved it.OK, this is just to prove if the higher latency is caused by that.
