Hi guys,
as you see on screenshot below disappeared the GPU 8-Pin #3 Input Power display in HWInfo64 7.02-4430.
The displayed GPU 8-Pin #3 Pin Voltage disappeared as well.
It should be displayed. The EVGA 3090 FTW3 Ultra Gaming is equipped with 3 PCIe calbles.
How can I solve this issue?
Start to analyze your hardware right now! HWiNFO has available as an Installer and Portable version for Windows (32/64-bit) and Portable version for DOS.
www.hwinfo.com
You might also try to do a "Restore Original Order" in sensor settings - layout in case the value became hidden.
