Hard Drive Shows Yellow !
db7win
I ran CHECKDISK on P:\ after HWINFO64 showed a Yellow ! and I got an error it fixed, yet it still shows. Why?
Thanks, Don
You drive probably reports some errors on the physical level, which cannot be fixed using software. Exact details depends on particular SMART parameters reported, which you can check in the main HWiNFO window.
I suggest to watch the drive and perform backups.
