How precise is HWiNFO?
Lothur
Hello there!
I've been using HWiNFO to compare my PSU voltages to those I see on some reviews.
My questions is, how precise is HWiNFO voltages in comparison to Physical measured ones?
For example, jhonnyguru reports my PSU +12v rail is outputting 12.5v, yet HWiNFO only shows 12v.
I know there are always some variations from PSU to PSU, but thats a huge variation.
Cheers!
Such values are measured using internal PSU circuits and there can be some difference between this and values measured using a more precise DMM.
But I too think that 12.5V would be a too big difference. Which PSU do you have?
Lothur
Hello Martin!
First of all thank you for taking your time to make this tool and to answer my question.
I'm using a Corsair rm750x.
The values jonnyguru.com measured where taken directly from the power cables that come from the PSU.
I was under the impression HWiNFO took its values from some kind of voltage regulators on the motherboard.
On this example, jonnyguru.com measured 12.5v, on the +12v line, on his rm750x.
Yet HWiNFO is showing that my +12 line is outputing 12v.
That's a 0.5v difference. I know every PSU is deferent and there might be slight fluctuations.
My questions is, how precise are the HWiNFO values versus values taken directly from the power lines?
I'm sorry, I have never compared such readouts with a DMM. HWiNFO only reports what the PSU measures using its own circuits, so I think you will get a better response on Corsair forums.
