how to show Mbps
thebonden
hey how dan can i get it to show numbers in Mbps there need not be syntax after
since I use stream deck and app HWINFO64
and since my ISP indicates the speed in Mbps then it would be cool to be able to see it in it so I know how much power of the connection I use
Use the "Custom" tab of sensor settings to set a custom "Multiply" value. Set it to divide by 1024, so use a value of 0.0009765625 (=1/1024).
