HWiNFO 5.30 doesnot display CPU Fan details.
hope you are doing good. I just installed the new version of the application(5.30) and tested on existing systems. It is working fine. But i face the same problem i.e. the CPU fan is not displayed on another system that i tried.
I have attached the screenshots, debug info and report for the system.
Could you please have a quick look into the attachments and update.
  • testpc.HTM
  • dddd.CSV
That Fujitsu machine uses proprietary solution to control/monitor fans (most probably BMC), thus it's not supported.
If the system supports IPMI that information might be accessible by HWiNFO, but it depends as I have seen issues with IPMI on some machines.
