HWINFO 6.4x.xxx (all versioins) too much Handles
dandee
Just want to report this issues with (all) 6.4x.xxx versions.
I have installed the latest beta (and stable) 6.4x versions but in task manager i notice that this new versions can generate up to 250k handles and significantly slowdown system performance.
to solve this i have to close hwinfo and run it again but after a couple of minutes it start to generate too much handles.
i have to revert to version 6.26.xxx that generate only 430 handles and stay on this handles count forever.
thank you very much for this tool.
Win10 20H2 2009
10900k
z490 aorus xtreme
32gb G.Skill Z-rgb
2080TI Aorus Xtreme AIO
Corsair HX1200i
Corsair AX1600i
Arctic Liquid Freezer II 420mm AIO
dandee
This is a know issue in monitoring of Corsair and will be fixed in the next Beta build.
Here's an interim build that should fix it meanwhile: www.hwinfo.com/beta/hwi64_641_4352.zip
Hello Mr Martin,
please allow me to directly thank you for your incredible work and support.
I know that other tools are available but i use HWInfo from dayone years and years ago.
thank you for the fix. i test it and report back what i find :).
thank you.
dandee
Mr. Martim,
this new version works as expected.
Handles are fixed to 470 and i have all VROut again.
thank you.
zogge
I find the AX1600i sensors, they report values once then go into disabled. I enable, same thing then back to disabled.
Corsair link not running and ticked it in settings for corsair support.
