On first months of Running 3.7 on a Ryzen 5 1600 with 1.25v with no CPU L1 Cache Error
And shows no CPU L1 Cache Error error even running Aida64 Stress Test for straight 8+hrs
Then went to 3.8 Ryzen 5 1600 with 1.32v and received a CPU L1 Cache Error
Then I saw some post about having it because of Overclocking..
Then I down clocked it to 3.7 with 1.25v since this was my first stable OC on stock cooler, but am now receiving the CPU L1 Cache Error
Then I picked up some volts 3.7 with 1.28v just to make sure. But still received some errors.
I'm currently running on 3.7GHz Ryzen 5 1600 and a GTX 1060
Kinda new to the CPU L1 Cache Errors.
I checked what goes to the Event Viewer Kernel-WHEA Error and showed me a list of error id with WHEA Error
I only remember swapping of my GTX 1060 to the next PCI-E slot. I reinstalled the Graphic Card Driver for it to work.
I searched from Microsoft https://msdn.microsoft.com/en-us/library/windows/hardware/ff560537(v=vs.85).aspx
for these errors only to find info. Still having Error ID 20
Any help would be appreciated.
Thanks and sorry for the long post.
UPDATE:
Just tried all default setting, just disabled Cool n' Quiet from the BIOS. Running 3.2Ghz 1.1v (Auto) Ram at 2133
Still receiving WHEA Error.
UPDATE 44 min,
Came back to 3.8Ghz at 1.3125v and 3066 RAM
IDK what happened. But I didn't run the HWinfo and just checked the event log viewer, still no WHEA error log. :s
UPDATE
Came back with around 6+ Whea Errors again. Will contact them, thanks Martin.
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-08-01T10:18:55.697844900Z[/b]" /> <EventRecordID>44</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]6012[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-08-01T10:06:55.697885500Z[/b]" /> <EventRecordID>43</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]8232[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-08-01T09:36:55.697971700Z[/b]" /> <EventRecordID>42</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]8232[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-07-31T06:01:09.587411500Z[/b]" /> <EventRecordID>41</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]8040[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-07-31T03:11:13.738092800Z[/b]" /> <EventRecordID>40</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]5208[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-07-31T02:48:13.737926800Z[/b]" /> <EventRecordID>39</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]8468[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-07-31T02:21:13.739702400Z[/b]" /> <EventRecordID>38</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]7784[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
Code:<Provider Name="[b]Microsoft-Windows-Kernel-WHEA[/b]" Guid="[b]{7B563579-53C8-44E7-8236-0F87B9FE6594}[/b]" /> <EventID>20</EventID> <Version>0</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000800</Keywords> <TimeCreated SystemTime="[b]2017-07-28T05:10:55.696427000Z[/b]" /> <EventRecordID>35</EventRecordID> <Correlation /> <Execution ProcessID="[b]4[/b]" ThreadID="[b]2860[/b]" /> <Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
UPDATE:
UPDATE 44 min,
UPDATE
