HWiNFO detects TR Pro Chipset as X570
ElCoyote_
I am using HWiNFO 7.30 to check some parameters (temps) on my ThreadRipper Pro build. Here are the mainboard specs:
- SuperMicro M12SWA-TF
- AMD TR Pro 5965WX cpu (24C/48T)
Scrolling down the list of sensors in HWiNFO, I saw this:
- Supermicro M12SWA-TF (AMD X570)
And it reports a sensors temp of 45C-50C.
I don't think those TR Pro motherboards have X570, I think it's called differently on that platform.
At any case, if the reported temperatures are from the TR Pro chipset, then I'm happy to report that the temps are stable even with the chipset fan removed.
This is just a naming issue, some TR chipsets are hard to distinguish from discrete X570 chips via software.
ElCoyote_
Agreed, but can I trust the temperatures reported by the sensor?
Also, the proper name for that chipset seems to be WRX80.
