HWinfo doesnot load
Tudor User
I downloaded HWinfor32 and installed it.    Initially it ran fine
However when i come back to the PC to run afresh, nothing happens when I click on the icon in the start menu.  I tried uninstalling and reinstalling.
I have a Surface Pro 4 (unfortunately) with an i7 processor.  I am on Windows 10
How do I get the program to run
Thanks
If you click on the HWiNFO icon and then open Task Manager, do you see the HWiNFO task running ?
If yes, please check in the tray (notification area) if you see HWiNFO there.
