byronsnake said:
Is there any way to show a scrolling graph of CPU temperature in the HWiNFO Rainmeter plug-in?
Yes, sure. The rainmeter measure(data) and meter(display) are two separate items. So you create a measure using this plugin (the sample skin has this)......and then you can feed it to one or more meteres of your choosing.
So you get the CPU data using a rainmeter measure which utilizes this plugin. You can grab the scrolling graph from any skin you want, or even create your own. Check the rainmeter.net forums and deviant art for zillions of skins, some of which already work with this plugin out of the box.
