HWiNFO v5.79-3390 Beta released
HWiNFO v5.79-3390 Beta available.
Changes:
  • Security hardening of the HWiNFO kernel driver.
  • Added support of Nuvoton NCT6797D/NCT5567D LPC/HW monitor.
  • Enhanced sensor monitoring of future MSI 3xx mainboard series.
  • Added fan speed monitoring on several new ASUS notebook models.
  • Fixed reporting of current DMI link speed for several Intel CPUs.
  • Fixed reporting of AMD Zen temperature when using alternate scale range.
  • Added support of some ACPI sensors on Windows 10.
  • Enhanced sensor monitoring on ASUS G11CD.
  • Enhanced support of Intel Denverton.
  • Added monitoring of new AMD GPU Memory Usage parameter.
  • Extended reporting of AMD graphics driver version.
  • Enhanced sensor monitoring on EVGA X299 DARK.
VictorVG
Before install v5.79-3390 additional operation required:
sc stop HWiNFO32 && sc delete HWiNFO32 && del /f /q %SystemRoot%\system32\drivers\HWiNFO64A.SYS > nul
for clean SCM base and delete old persistent driver.
If anyone experiences a problem with starting the new driver, please attach the HWiNFO Debug File so I can analyze this.
wawans1975
Seems GPU thermal diode sensor for IGP is missing , why? I see it's not the same sensor as CPU Tdie , because it shows different value.
Other sensor (VDDCR_SOC) for  IGP seems missing too, but I just curious for GPU thermal diode..
Is this a problem of the latest Beta builds only? Please attach the HWiNFO Debug File so I can check that.
wawans1975
I have build  5.79 -3383 and 5.71.3330 those have GPU Thermal Diode sensor, yes just with new beta build.
Add: running furmark for IGP, the VDDCR_CPU stays at 0.001V
