HWiNFO v6.27-4195 Beta released
HWiNFO v6.27-4195 Beta available.
Changes:
  • Fixed and improved monitoring of VR VCC sensor on Intel SVID VR systems.
  • Added per-rail voltage and power monitoring on NVIDIA GPUs.
  • Enhanced sensor monitoring on ASUS ROG STRIX B460 series.
  • Fixed a possible crash on some systems with down-cored CPUs.
  • Added reporting number of RT and Tensor Cores for NVIDIA (requires R445+).
  • Enhanced sensor monitoring on ASUS Pro WS W480-ACE.
  • Enhanced sensor monitoring on ASUS ROG STRIX B550-E/I GAMING.
  • Enhanced sensor monitoring on ASRock H470, B460 and H410 series.
  • Enhanced sensor monitoring on ASRock W480 Creator.
  • Improved support of hybrid CPUs (Alder Lake).
  • Enhanced sensor monitoring on GIGABYTE B550 series.
  • Enhanced sensor monitoring on MSI B550 series.
  • Added dedicated support of LSI MegaRAID controllers. Requires LSI storelib*.dll libraries.
  • Fixed support of Intersil ISL69269 VRM.
  • Added monitoring of Power Reporting Deviation on AMD Ryzen CPUs.
  • Enhanced sensor monitoring on ASUS ROG STRIX B550-F and PRIME B550 series.
  • Enhanced sensor monitoring on ASUS TUF GAMING B550-PLUS.
  • Fixed monitoring of Power Reporting Deviation on AMD 1st/2nd Gen Ryzen CPUs.
Build 4195 adds some important changes to the "Power Reporting Deviation" parameter:
- The tolerance threshold has been increased from 5% to 10%.
- Values below 90% will be shown in red color to denote under-reporting.
- This parameter will not be shown if OC Mode is enabled.
- Removed reporting of this parameter on sTRX4 systems.
There will be a more detailed explanation posted by The Stilt soon.
EDIT: Posted here. I strongly encourage everyone interested in this topic to read that post.
1.) I could not see Power Reporting Deviation on V4195Beta anymore. see also V4190 screenshot
2.) with Ryzen 3950x / X570 Aorus xtreme with default setting (only XMP active) PRD is 92% under load
with fixed clock (4150MHz) and PBO activated the PRD is now 142% under load (BOINC % [email protected])
2020-06-18 23_35_23-HWiNFO64 v6.27-4190 Sensor Status [196 values hidden].jpg2020-06-18 23_34_47-HWiNFO64 v6.27-4195 Sensor Status [196 values hidden].jpgBIOS_1.JPGBIOS_2.JPG
  • 2020-06-18 23_35_23-HWiNFO64 v6.27-4190 Sensor Status [196 values hidden].jpg
  • 2020-06-18 23_34_47-HWiNFO64 v6.27-4195 Sensor Status [196 values hidden].jpg
Is OC Mode perhaps enabled there? You can check that in the main window.
hi martin
of cause is OC enabled, that's the difference in PRD seen in V4190 (92% in default bios, 142% with fixed clock and VID = BIOS_1 & _2))
but why is PRD not visible in V4195?
hi martin
Have you read the comments above?
