HWiNFO v7.01-4410 Beta released
HWiNFO v7.01-4410 Beta available.
Changes:
  • Enhanced sensor monitoring on ASRock Z590 OC Formula and Z590 Phantom Gaming-ITX.
  • Fixed unintentional waking up of some NVIDIA dGPUs disabled by Optimus technology.
  • Added reporting of PCI Express Resizable BAR capability and status for all devices.
  • Enhanced sensor monitoring on MSI Z590 PLUS, MEG Z590 UNIFY and B560M PRO WIFI.
A note regarding the new Resizable BAR information.
This is available for all PCI Express devices (not only GPUs) in the main window - Bus under each device node:
This feature supports individual settings for multiple BARs (Base Address Registers). For AMD BAR0, for NVIDIA BAR1 is of most interest as for GPUs this is the framebuffer memory space that will see a performance improvement when this feature is enabled and properly handled.
The first item (Supported Size) specifies the device capability and is independent from BIOS or drivers. Each device can support different sizes.
The second item (Current Size) specifies the actual setting. This depends on whether the BIOS is supporting this feature and enables it.
On the above GPU example, the 8 GB (maximum) current size means this feature is enabled as it extends the BAR size from legacy 256 MB to 8 GB. When the BIOS doesn't support or enable this feature, the current size would be 256 MB.
This information is also shown for each GPU with a simplified format (BAR0 only):
This shows whether the capability is supported by device and actual state set by BIOS (>256MB is treated as supported).
