HWiNFO v7.05-4495 Beta released
HWiNFO v7.05-4495 Beta available.
Changes:
  • Added LHR variants of NVIDIA GeForce RTX 3080, 3070 and 3060 Ti.
  • Fixed reporting of memory clock and some other parameters on Rocket Lake 6c/4c.
  • Enhanced early support of some Zen4-based systems.
  • Added workaround for systems with stuck SMBus causing large delays.
  • Added VRM monitoring on ASRock Z590 Extreme, Z590 Phantom Gaming 4, H570 Phantom Gaming 4, H570 Steel Legend, B550 Extreme4, B550 PG Velocita.
  • Added several NVIDIA GeForce RTX 3070 Ti and 3080 Ti card models.
  • Enhanced sensor monitoring on GIGABYTE X570S series.
  • Added option to use RFC 3339 or ISO 8601 date formats for sensor logging.
  • Added support of Intel XMP 3.0 for DDR5.
  • Added per-core temperature monitoring for AMD Zen CPUs.
Of course it is, it was just AMD not sure whether users need to watch this to avoid confusion.
Well, there might be some additions in the future... ;)
kr0mka
Not sure how to enable the per-core monitoring? I have a 5900X and 4495 looks the same to me as the previous version.
kr0mka
1.2.0.2 as this is the newest one for X570 Tomahawk
edit: oh, 1.2.0.3b dropped just today, will check it out
Can you try with stock BIOS settings?
Also when it still won't work with 1.2.0.3b please attach a new Debug File.
kr0mka
Alright, I've flashed 1.2.0.3b and restored the default settings, it works now, even after applying my custom settings afterwards. So either restoring the stock settings has helped or the new 1.2.0.3b agesa had. Sorry for not testing this separately but I was mid bios flash already when you replied.
SpeedyIV
I could not see the individual core temps until I restored default layout settings, then closed and re-opened HWINFO64. I am running a 5950X on an Asus CX-8 Dark Hero running latest non-beta BIOS 3601 with AM4 AGESA V2 PI 1.2.0.3 Patch A. Just updated BIOS so everything is at defaults except disabling CPU_FAN monitoring. After the individual core temps appeared, I restored my previous custom settings successfully. Hope this is helpful.
MrAgapiGC
Changes:
Hi Martin I have try to download the 7.05 and on here and normal website, the version that i am getting is 7.04
