HWiNFO v7.11-4570 Beta released
HWiNFO v7.11-4570 Beta available.
Changes:
  • Added a darker (black) Dark Mode skin.
  • Increased font and window size of the summary window.
  • Updated summary window for improved support of Hybrid CPUs.
  • Changed core naming in Hybrid CPUs to better reflect the type.
  • Added a workaround for missing CPU clocks on AMD CPUs with Core Isolation / Memory Integrity enabled.
  • Fixed a possible crash when opening sensor settings multiple times.
  • Added support of Alder Lake-N.
  • Enhanced sensor monitoring on some ASUS MAXIMUS, STRIX, TUF, ProArt, PRIME Z690 and B660 series.
  • Added ability to define a custom range for invalid sensor values.
  • Redesigned Summary window.
This new layout was chosen also because the list boxes at bottom will automatically adjust the height based on number of items inside and one won't need to scroll them.
wawans1975
.. because on my 14inch display laptop (using recommended display resolution 1080p and recommended 150% scale), summary windows fill screenfrom left to right (2/ 3 screen) , and sensor windows just fit small portion (1/3 screen) at bottom screen from left to right.
new layout if fine on desktop PC with 27inch monitor(1080p resolution).
