HWiNFO v7.14 released
HWiNFO v7.14 available.
Changes:
  • Added initial support of Raptor Lake-S and Raptor Lake-P.
  • Changed layout of DDR5 DIMM sensors to one sensor per DIMM.
  • Added monitoring of several parameters for each DDR5 DIMM.
  • Fixed reporting of voltage offset set via V/F curve for Intel CPUs.
  • Added reporting of voltage/frequency curve setting for Intel CPUs.
  • Enhanced sensor monitoring on some ASRock Z690 series.
  • Added reporting of Hypervisor-protected Code Integrity (HVCI) setting.
  • Enhanced support of next-generation AMD APUs.
  • Added graph Auto Fit feature.
  • Minor fixes for Alder Lake support.
  • Fixed monitoring of Aquacomputer Quadro and Octo with new firmware.
  • Added reporting of AMX support in summary.
  • Improved monitoring of DDR5 PMIC parameters.
  • Enhanced sensor monitoring on EVGA X570 FTW and X570 DARK.
  • Enhanced sensor monitoring on EVGA Z690 CLASSIFIED and Z690 DARK KINGPIN.
  • Changed reporting of Memory Command Rate to not depend on Gear Mode.
  • Fixed swapped GPU Right/Ext fan on EVGA iCX with new firmware.
