HWiNFO v7.65-5250 Beta released
HWiNFO v7.65-5250 Beta available.
Changes:
  • Added fan speed monitoring on ASUS VivoBook X513.
  • Added command-line argument to exclude processes in PresentMon.
  • Fixed monitoring of VRM HS Fan on ASUS ROG STRIX Z690-I and X670E-I.
  • Enhanced monitoring on ASUS TRX50 and WRX90E series.
  • Enhanced reading of DIMM SPD on AMD Storm Peak systems.
  • Added new Intel Arc models.
  • Minor updates and bugfixes.
Depends what you consider "normal readout" :) 0 can mean the 3D application is no longer running or FPS can't be determined.
i just sent you sensor csv log when playing movie that use directx, no zero framerate when change to older HWINFO64
  • movieplaydirectx.zip
0 is now returned when the FPS is not possible to determine or the application doesn't produce frames. This was an intentional change to especially avoid showing the last FPS when the application is stopped.
