HWiNFO64 crashes when activating sensors
jluis.oo
Hello HWiNFO team,
I am experiencing a problem with HWiNFO64 v7.01-4420 and now also with HWiNFO64 v7.01-4425.
The application crashes when opening sensors.
This problem does not happen with previous versions (HWiNFO64 v7.01-4415 and before).
This problem does not happen with HWiNFO32.
Please find attached the report and debug files generated with HWiNFO64 v7.01-4425.
Thank you very much for your help.
  • LOG_DBG.zip
Can you please do a "Backup User Preferences" in main settings and attach the file here too? You might need to compress it before attaching.
jluis.oo
Please find attached the file.
Thank you and best regards.
  • HWiNFO64_settings.zip
jluis.oo
This build is working very good, the issue is not present anymore.
I will continue using it and report any observation.
Thank you very much.
daknoll
As for the thread opener, i have the same crash problems with the same two versions here, but the crashes are also gone with the here posted 7.01-4427.
Thank you Martin!
