HWiNFO64.DBG Report
Sensor aida64 ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type Winbond W83667HG (ISA 290h)
GPU Sensor Type Diode, Volterra VT1165 (ATI-Diode, 70h)
Motherboard Name Asus P6T / P6X58D Series
Chassis Intrusion Detected No
Temperatures:
Motherboard 29 °C (84 °F)
CPU 27 °C (81 °F)
CPU #1 / Core #1 40 °C (104 °F)
CPU #1 / Core #2 37 °C (99 °F)
CPU #1 / Core #3 39 °C (102 °F)
CPU #1 / Core #4 38 °C (100 °F)
GPU Diode (DispIO) 35 °C (94 °F)
GPU Diode (MemIO) 41 °C (105 °F)
GPU Diode (Shader) 40 °C (103 °F)
GPU VRM 30 °C (86 °F)
WDC WD1001FALS-00U9B0 25 °C (77 °F)
Cooling Fans:
CPU 1029 RPM
Chassis #1 469 RPM
Chassis #2 2519 RPM
Chassis #3 482 RPM
Power Supply 1096 RPM
GPU 1019 RPM (21%)
Voltage Values:
CPU Core 0.928 V
+3.3 V 3.200 V
+5 V 4.968 V
+12 V 11.984 V
+5 V Standby 5.139 V
GPU Core 0.950 V
GPU VRM 0.950 V
Current Values:
CPU 5.27 A
GPU VRM 2.32 A
Power Values:
CPU 5.63 W
GPU VRM 2.21 W
Debug Info F 2D 52 4D / 43 AF
Debug Info T 29 27 27
Debug Info V 74 D6 CA C8 CF FF 8B (03)
Debug Info I C1 A513
Sensors HWiNFO64 Version 4.60-2460 12.04.2015 14:38:16 ---------------------------------------------
[System]
Virtual Memory Commited 2085 MB
Virtual Memory Available 10182 MB
Virtual Memory Load 16.0 %
Physical Memory Used 1595 MB
Physical Memory Available 4540 MB
Physical Memory Load 25.0 %
[CPU [#0]: Intel Core i7-930]
Core #0 Clock 1570.5 MHz
Core #1 Clock 1570.5 MHz
Core #2 Clock 1570.5 MHz
Core #3 Clock 1570.5 MHz
Bus Clock 130.9 MHz
Uncore Clock 2094.0 MHz
QPI Clock 2355.7 MHz
Core #0 Thread #0 Usage 7.5 %
Core #0 Thread #1 Usage 0.0 %
Core #1 Thread #0 Usage 15.7 %
Core #1 Thread #1 Usage 0.7 %
Core #2 Thread #0 Usage 4.7 %
Core #2 Thread #1 Usage 0.0 %
Core #3 Thread #0 Usage 11.5 %
Core #3 Thread #1 Usage 2.3 %
Max CPU/Thread Usage 15.7 %
Total CPU Usage 5.3 %
On-Demand Clock Modulation 100.0 %
Core #0 Thermal Throttling No Yes/No
Core #1 Thermal Throttling No Yes/No
Core #2 Thermal Throttling No Yes/No
Core #3 Thermal Throttling No Yes/No
Core #0 Ratio 12.0 x
Core #1 Ratio 12.0 x
Core #2 Ratio 12.0 x
Core #3 Ratio 12.0 x
Uncore Ratio 16.0 x
QPI Ratio 18.0 x
[CPU [#0]: Intel Core i7-930: DTS]
Core #0 41.0 °C
Core #1 38.0 °C
Core #2 40.0 °C
Core #3 38.0 °C
Core Max 41.0 °C
[ASUS P6T DELUXE V2 (Winbond/Nuvoton W83667HG)]
Motherboard 34.0 °C
CPU 24.5 °C
Auxiliary 24.5 °C
SYSTIN3 18.0 °C
Vcore 0.928 V
+12V 12.081 V
+3.3V 3.232 V
+3.3V 3.200 V
+5V 4.999 V
VIN6 2.320 V
3VSB 3.392 V
CPU 1028 RPM
Power 1054 RPM
Chassis Intrusion Yes Yes/No
[ASUS P6T DELUXE V2 (On Semi ASP0800 (ASUS EPU2))]
VR VOUT 0.950 V
VMON 0.945 V
VTT 1.066 V
Current (IOUT) 5.492 A
Power (POUT) 5.617 W
[S.M.A.R.T.]
INTEL SSDSA2M080G2GC [CVPO0133005S080BGN] Remaining Life 92.0 %
INTEL SSDSA2M080G2GC [CVPO0133005S080BGN] Drive Failure No Yes/No
INTEL SSDSA2M080G2GC [CVPO0133005S080BGN] Drive Warning No Yes/No
[S.M.A.R.T.]
WDC WD1001FALS-00U9B0 [WD-WMATV6501614] 25.0 °C
WDC WD1001FALS-00U9B0 [WD-WMATV6501614] Drive Failure No Yes/No
WDC WD1001FALS-00U9B0 [WD-WMATV6501614] Drive Warning No Yes/No
[Drive: INTEL SSDSA2M080G2GC]
Read Activity 71.2 %
Write Activity 20.8 %
Total Activity 92.0 %
Read Rate 4.356 MB/s
Write Rate 16.198 MB/s
[Drive: WDC WD1001FALS-00U9B0]
Read Activity 0.0 %
Write Activity 0.0 %
Total Activity 0.0 %
Read Rate 0.000 MB/s
Write Rate 0.000 MB/s
[GPU [#0]: ATI/AMD Radeon HD 5870: ]
GPU Thermal Diode 34.0 °C
GPU TS0 (DispIO) 34.5 °C
GPU TS1 (MemIO) 40.5 °C
GPU TS2 (Shader) 39.5 °C
GPU VDDC 0.950 V
GPU Fan 1022 RPM
GPU Clock 157.0 MHz
GPU Memory Clock 300.0 MHz
GPU Utilization 0.0 %
GPU D3D Usage 0.7 %
GPU Fan Speed 21.0 %
GPU D3D Memory Dedicated 105 MB
GPU D3D Memory Dynamic 27 MB
PCIe Link Speed 5.000 Gbps
[GPU [#0]: ATI/AMD Radeon HD 5870: Volterra VT1165]
GPU VRM Phase1 29.0 °C
GPU VRM Phase2 29.0 °C
GPU VRM Phase3 30.0 °C
GPU VRM Phase4 31.0 °C
GPU VRM Voltage 0.950 V
GPU VRM 2.323 A
[Network: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller]
Sensors HWiNFO64 v4.60-2460
[System]
Virtual Memory Commited 2035 MB
Virtual Memory Available 10232 MB
Physical Memory Used 1551 MB
Physical Memory Available 4583 MB
Core #0 Clock 1570.4 MHz
Core #1 Clock 1570.4 MHz
Core #2 Clock 1570.4 MHz
Core #3 Clock 1570.4 MHz
Bus Clock 130.9 MHz
Uncore Clock 2093.9 MHz
Core #0 Thread #0 Usage 4.2 %
Core #1 Thread #0 Usage 1.5 %
Core #1 Thread #1 Usage 0.3 %
Core #2 Thread #0 Usage 1.1 %
Core #3 Thread #0 Usage 1.5 %
Core #3 Thread #1 Usage 0.0 %
Max CPU/Thread Usage 4.2 %
Total CPU Usage 1.1 %
Uncore Ratio 16.0 x
QPI Ratio 18.0 x
Core #0 43.0 °C
Core #1 40.0 °C
Core #2 42.0 °C
Core #3 40.0 °C
Core Max 43.0 °C
Motherboard 38.0 °C
CPU 27.5 °C
Auxiliary 21.5 °C
SYSTIN3 18.0 °C
Vcore 0.928 V
+12V 12.081 V
+3.3V 3.232 V
+3.3V 3.200 V
+5V 4.999 V
VIN6 2.464 V
3VSB 3.392 V
CPU 1028 RPM
Power 1171 RPM
VR VOUT 0.944 V
VMON 0.939 V
VTT 1.068 V
Current (IOUT) 4.586 A
Power (POUT) 4.516 W
[S.M.A.R.T.]
[S.M.A.R.T.]
WDC WD1001FALS-00U9B0 [WD-WMATV6501614] 27.0 °C
Read Activity 0.0 %
Write Activity 3.5 %
Total Activity 3.5 %
Write Rate 0.342 MB/s
Read Activity 0.0 %
GPU Thermal Diode 38.0 °C
GPU TS0 (DispIO) 38.5 °C
GPU TS1 (MemIO) 43.5 °C
GPU TS2 (Shader) 43.0 °C
GPU VDDC 0.950 V
GPU Fan 1049 RPM
GPU Clock 157.0 MHz
GPU D3D Usage 1.7 %
GPU D3D Memory Dedicated 108 MB
GPU VRM Phase1 33.0 °C
GPU VRM Phase2 32.0 °C
GPU VRM Phase3 33.0 °C
GPU VRM Phase4 34.0 °C
GPU VRM 2.323 A
